Driver side door controls stopped working
John49
Indiana
Ford ranger
One day all controls on driver side door stopped at same time. Windows,door lock and mirror control
I checked all switches they and are getting power to them. I applied power Directly to window motors at connector and motor works
door locks work with keyfob and passenger side switch
I put new power window switch and lock switch in. Still nothing
I’m getting power at the wiring cable ends for each switch Thanks fir any info
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
I would check the grounds.
ericbphoto
Overlander in development
16,511
Wellford, SC
6"
:iamwithstupid:
Yup. Reads like a loose/broken ground.
John49
Indiana
Ford ranger
Thanks. I will dig deeper in wiring
8,369
Grounds for that door are behind the kick panel
But..............passenger window shouldn't work if the Master switch ground is bad
Door locks have full time 12v, well their relays do
Windows are Key On power only
So separate systems entirely
Only thing they have in common, besides driver door location, is the SJB(smart junction box), cab fuse panel is part of the SJB
So you may need to disconnect battery, then pull the passenger kick panel and then pull out each of the large wire connectors on the SJB and look for corrosion, a common issue with these, clean and reconnect
