driveline whine
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
There's always some in and out play of the axle shafts. Its just the nature of a c-clip style differential, nothing is there to actually tighten the axles down. 1/4" would be on the high end of that though. Probably worth popping the cover off to have a look...
machinistmike
Kingsport TN
had the chance to work on truck today. ended up replacing both rear bearings and seals. also found pinion shaft seal was bad which we replaced. still have a roar but not as bad. any other suggestions?
machinistmike
Kingsport TN
explained problem to repair shop and they seem to think i have worn ring and pinion. more updates when i get those replaced
machinistmike
Kingsport TN
here wasmy main problem. had to grind part of a tooth on new ring gear toget pin out enough to install c clips. once i got it together its quiet once again
