Driveline noise
Shadowranger
18
Puerto Rico
Ranger XLT 4x4
2001 Ranger XLT 4.0 4WD has a driveline noise that will kill what's left of my hearing.
Has 141,000 mi. and it's had the u joints checked (not lately tho.) and timing chain replaced, lots of maintenance work done over the last 2-3 years .
At 35-40 mph the noise is loud. But it runs like a champ otherwise. Axles are ok on gear oil.
I'll be having the mechanics check it out but in the meantime any ideas? thanks
rusty ol ranger
2.9 Mafia-Don
8,573
Michigan
177 CID
What kind of noise?
Grinding? Squeel? Humming?
Shadowranger
18
Puerto Rico
Ranger XLT 4x4
Humming. no grinding or squeal
rusty ol ranger
2.9 Mafia-Don
8,573
Michigan
177 CID
My 97 F250 did this for a while and it turned out to be a broken accessory bracket on the engine.
Not saying thats your case.
Usually a hum indicates a bad wheel bearing. Espicially if the tone changes/goes away when cornering.
Shadowranger
18
Puerto Rico
Ranger XLT 4x4
The tone is mostly noticeable going straight down the road and seems to be coming from the front of the truck.
rusty ol ranger
2.9 Mafia-Don
8,573
Michigan
177 CID
More then likely its a wheel bearing
superj
3,474
corpus christi, texas
ranger edge
182 ci of tire shredding power
2, so far
235s
drives a stick shift ranger
do some s turns going down the road and if the noise is almost gone when turning one way but comes back turning the other, its for sure a wheel bearing.
Shadowranger
18
Puerto Rico
Ranger XLT 4x4
I'll try that as soon as I get it back from the mechanic. Driver side valve cover gasket leaks oil and you know the crap that needs to be taken out of the way to get to it?
I can do the passenger side but not the driver's side. It's a nightmare if you haven't done it. Thanks--I'll be back.
Shadowranger
18
Puerto Rico
Ranger XLT 4x4
rusty ranger! Correct! Wheels bearings it is. Not the kind I could have done back in the day though. Complete assembly for both front axles with lug studs, etc.
$143. at Auto Zone, each. Wow.
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,785
Wellford, SC
6"
Glad you got the problem identified.
No members online now.
Rick W
October Truck of The Month
25th Anniversary Merch
