Drive Shaft Swap
spin
Mazda
Thought I'd let everyone know what I did, maybe it will help someone else in the future. There is a tech article on the swap that I read, but it left some things out or was unsure.
My truck: 1995 Mazda B2300 Extended Cab 5spd 4x2.
My center support bearing for the 2 piece drive shaft took a crap. I replaced it with an aluminum one from a 99 ranger 3.0 ext cab 5spd 4x2. As the tech article says use the same drive train and wheel base. The swap works as stated in the article.
Here is where the article here wasn't clear. The tech article on this website said you needed to swap the differential flange because it was a different size. I read another article that said 1990 and up you did not need to swap the flange. The other article was right. Straight swap after you remove the center support bearing bracket (not the cross member).
Hope this helps someone else
Sorry, I didn't take pictures
mp3deviant721
24
Eau Claire, WI
2.3l of fury
Some people have said that they have removed that crossmember that supports the support bearing without any issues.
Irokranger93
Michigan
what makes me most is the shit F**ing nut to 12 points on the yoke
THERE have not been able to put ****ing nut with 6 points, I shit whore hobs to loosen a key
TexasDuck66
July Truck of The Month
