veefer800canuck
- Sep 7, 2007
- Reaction score
- 7
- Location
- Alberta
- Make / Model
- Ranger FX4
- Engine Size
- 4.0
- Manual
Mustang Cobra wheels are on!
<edit: pics at the bottom>
It's a little late, as I already have the wheels in the garage, and some parts coming from Ebay, but I just wanted to settle my mind 100% on how this will work. I'm about 99% at the moment, LOL.
the rims are OEM Mustang Cobra's, 16x8, truck is '95 Ranger 2wd, mostly stock suspension, with the exception of stock 2008 4WD springs and hangers in the rear, no flipped links or anything.
backspacing is as close to 5" as I can measure, according to some gOOgling, it's actually 5.09", compared to 4.5" for the Explorer 16x7 rims I had on the truck before.
I have already Test-fit one rim on the front of the truck with both the 225 and 245 tires which came with the rims (tires which I am not using as they are /50 profile, so too small) and there was plenty of room turning the wheel from lock to lock even with the 245's. I could fit my hand between the sway bar and the tire up to the 3rd knuckle. So no rubbing problems.
I will be running 235/60-16's front and 255/55-16 rears.
2.7% larger diameter front, 2.4% larger diameter rear as compared to stock 225/70-14's
for the front wheels, I ordered some 5mm alloy wheel spacers, because the plastic center caps were lightly hitting the bearing hub grease caps by about 3mm or so, and being slightly pushed out when tightened.
I also ordered 20 ET style lug nuts like these, to compensate for the thickness of the front spacers (can use them in the rear also with no spacers due to the thickness of the rims):
the bottom extended part of the ET lug nuts is .61" width and the lug holes in the rim are .62" so that should not be a problem.
On to the center bore, ranger is 70.3mm from what I can gather, and the mustang wheels are the same I think.
So can anyone think of concerns I should address??
