Door lock moving
Irishtat74
07461
Ford Ranger xlt
Ok here's one either my truck is haunted by my dad or hes trying to tell me something. Changed the serpentine belt now truck is harder to crank over and the door locks while cranking ........anyone ever seen this before or heard of it?
ericbphoto
Overlander in development
16,580
Wellford, SC
3.0L
6"
Thats a weird one.
Maybe you bumped a ground connection loose. Check the one on the radiator support near the driver side headlight.
8,369
I would check battery terminals, clean them
If voltage is dropping too low when starter motor is on it can cause electrical glitches like the door locks cycling
Would also explain the slow cranking speed.............low voltage
Battery should be 12.3v to 12.8v after sitting a few hours, 12.2v or less is a failed battery, 5/6 years old
Then voltage should stay above 9.8volts while cranking, it drops about 2.5v when cranking
After startup battery should read 14.0-14.8 volts, than means alternator is working
Irishtat74
07461
Ford Ranger xlt
Thanks I'll check out the battery and check the ground. Battery might be 5 years old now that I think about it. But volt meter is usually around 12 when starting an 14 when running.
sheep herder
1,024
sheep pen
If it ain't broke, break it.
Pull the belt back off and make sure all the accessories spin freely. That's what got @PetroleumJunkie412 .
8,369
I think you mean 12v before starting, and yes, but during starting it should drop by 2volts but no lower than 9.8volts or there can be problems
Irishtat74
07461
Ford Ranger xlt
So turned key on it was at 10 v. Cranking it drops to 7.3 -6.5 then once started shot up to 14.3 I'm thinking its going to be the battery
8,369
LOL. yes, that would be a battery issue
Surprised it even turns over, you are in the "click, click, click" voltage area
1990RangerinSK
1,312
Saskatchewan, Canada
Question: How long has the truck been sitting? Reason I ask is that there are some accessories (ECU, radio) that draw power even while the truck isn't running. I've seen my own vehicles sit more than a month, and then the battery is dead, or near dead, but once it's charged up again, it's fine.
Before you replace the battery, try charging it.
Oh, one other thing: I see you're in New Jersey (your zip code). I'm pretty sure it freezes there, and stays frozen, for a couple of months in the winter. If the truck has been sitting over the winter with a dead battery, the battery froze, and it's done.
One way to tell that it's been frozen is that the case bulges.
Irishtat74
07461
Ford Ranger xlt
Truck is my daily driver. So it's only sitting over night. The strange thing is it start doing this after I changed the serpentine belt.
Irishtat74
07461
Ford Ranger xlt
New battery. Let's see what happens. Now I just have to figure out why it's leaning to one side. .
8,369
Broke rear leaf spring hanger on the low side :)
ericbphoto
16,580
Wellford, SC
3.0L
6"
I bet the driver side is the low side.
Uncle Gump
Token Old Guy
13,452
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Mine leans passenger...
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,628
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
Spring hanger could be rotted out as well.
