- Jan 12, 2021
- 827
- Walkerton Va 23177
- Ford Bronco II
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
So just an FYI my 2020 Ranger door lock buttons in the cab all quit working. Key fob and App worked but not on the doors. Little indicator light was out as well on each switch. Took to the dealership, one day diagnosis needs VCU or whatever Ford terms the vehicle controller as, obviously I knew that wasn't going to fix it but sure 7-8k miles loaner vehicle I don't care throw parts at it.. sure enough over a month later when the controller comes in drop the truck off. Ford, " we will need the truck over the weekend had to order another part". Fine by me with one exception, did you screw something up on my truck or just miss diagnose? Miss diag. Ended up being a wire in the right front door chafed on a stud on the window frame. So if anyone has a similar issue, heads up..
