Door lock actuator help.
warhawk
Grand Haven, Mi
4.0L SOHC
I'm changing out my passenger door lock actuator, I was wondering if anyone had and trips or tricks on how to do it. I have directions from my truck CD but I didn't know if anyone knew a better way. I have a 2000 Ranger XLT with the power package. Thanks guys.
Jeepman401
CT
What does it tell you to do
I know some directions tell you to remove the window, but you can get by with just loosening the window track
warhawk
Grand Haven, Mi
4.0L SOHC
The directions just tell me to remove the window track, I don't think it says to remove the whole window. I was planning on rolling up the window and trying to pull out the locking mechanism. I do have one question, is there a way to unfasten the lock actuator while it's still inside to door?
alain
Laval, Quebec, Canada
Mazda
Remove your inner door panel.
The actuator is located in at the bottom/rear of the door.
It's held in place by a single pop rivet. Simply drill the rivet.
Unhook the electrical connection.
That it.
warhawk
Grand Haven, Mi
4.0L SOHC
Thanks for the help guys, I swaped out the actuator today over lunch. Everything works great.
sdmsc
...Simply drill the rivet.
That it.
That answers the question I had. Just pulled the inner panel off on my '98 and as far as I could tell someone had decided to make the lock actuator 'non-serviceable'. 'spose I'll clean this window track grease off my arm and go get the drill...
[If I still worked in Dearborn I'd track down the knucklehead who made that decision and rivet their doors shut.]
sdmsc
Ok, this little motor is running ~$100 at the few sites that claim to have it. Anyone got a better source?? Or a 3rd party replacement that's not a bear to fit?
alain
Mazda
You can use an universal one, 10 to 15$, it will fit easily. better yet, try to find one use in a boneyard
coffee
Buena Vista, Ga.
Get power door lock actuators from www.electri-life.com. These people make good stuff and stand by it. I've used their power window conversion for the Ranger and it was a bolt up deal. Their power locks aren't bad to install. Whatever you do, stay away from auto-loc like herpes.
dburton07
5
South Portland ME
3.Ugh
is it the same deal for 93? my driver side wont work. when i hit the switch, it moves, but its like its stuck or somthing, my pops n i looked at it in the door n everything looked fine, squirted some marvel on it, no dice. i probably need a new one eh?
Kirby N.
March Truck of The Month
