dome light without eletricity
GabrielBR
Anápolis-GO Brazil
FORD
Hello,
My firts post in here, and i'm from Brazil, so my english insn't the best. I hope this is the right place.
I own a 1995 ranger single cab, and since I bought it, the door ajar advise was on at the panel, so the last owner removed the sound alarm that says the lamps are on, door's opened and another stuffs.
Important to mention that the dome light was unpluged, so it wasn't staying on all the time, but if I got the wires pluged it worked.
Now the door ajar sing is mysteriously off :icon_confused:, so I decided to plug the lamp inside the dome, but for my surprise it doensn't turns on.
I took a test and there's no electricity going at the lamp, SO HERE'S MY QUESTION:
Is the best solution to get electricity again, redo the wire or have anybody had these problem and took another solution?
Can a good soul take a picture showing were is the sound alarm instaled? and is possible to find another one to buy?
8,369
Welcome to TRS :)
1995 Ranger will have a GEM(generic electronic module)
The GEM controls all the electrics in the Cab.
GEM is located behind the Radio
Each door has a switch, when door is Closed switch is Open, when door is Open switch is Closed(grounded)
These switches often got stuck Closed(grounded) so Door Ajar light stayed on, popular fix was to spray WD40 into the door latch and open and closed the door a few times to get it unstuck.
GEM is connected to each door with 1 wire, if either wire is Grounded(door Open) GEM closes the Interior Lamp Relay and the Dome Light and "Door Ajar" light up.
So if one of these wires shorted to metal then it would be a Ground
Dome light Power comes from Fuse #27 in cab fuse box, but it powers other electrics as well
Interior Lamp Relay is usually found in RELAY BOX 1, located just above gas pedal under the dash, there are a few Relays in there including Battery Saver Relay.
Wiring diagram here
GabrielBR
Anápolis-GO Brazil
FORD
Welcome to TRS :)
Wiring diagram here
Thaks for the answer!
Well, I have forgot to mention that some time ago a fuse was in short circuit, it was located near the pedal, under the wheel, and i took it out. I attached some pic, so can you answer me if it is relacioned to the dome or "door ajar"?
Otherwise, I have tested all the fuses too, and they are ok.
About the ding when door is opened, is there is a way to reinstall it?
8,369
The picture is a Relay not a fuse
From description of location it was in Relay Box 1
And could be the interior light relay
It is powered by fuse #27 15amp
That relay is rated at 30amps, so should have been protected from a short by the 15amp fuse
So there may be a short in the Relay Box 1 or wire loom feeding relay box
GabrielBR
Anápolis-GO Brazil
FORD
Thank's for the answer, on the weekend i will see if this relay is or not this relay inside the box, but probably this is the problem.
but another question is if there's a way to reinstall the door ajar buzzer, and the main question is if I can buy it online or just find at junkyard?
PS.: I bought new door ajar switches for both doors, so they will be replaced son.
8,369
GabrielBR
Anápolis-GO Brazil
FORD
No, in a 1995 Ranger the "Chime/buzzer" will be built into the GEM, module that controls the electrics in the cab, it is located behind the radio.
Looks like this: https://www.ebay.com/itm/NOS-New-Genuine-OEM-1995-Ford-Ranger-Mazda-B2300-3000-4000-GEM-Module-/281799899862
You can take it apart and solder in a new chime/buzzer
This pic is of my relay box 1. I removed the relay that controls the dome light. So, beyond that relay that I removed, is missing another one?
Does the Chime/buzzer have a relay too?
8,369
No, as said the chime will be inside the GEM
17,770
SW Iowa
Check to make sure the wiring to the switches at the doors is working correctly.
My '85 would pop fuses as fast as I could put them in, mice had chewed the door switch wiring behind the parking brake mechanism on the LH side of the truck.
