Does Taurus 3.0 V6 Vulcan have the same engine mounts as the respective Ranger engine?
devildog2000
California
Considering picking up a taurus engine as a backup for my 3.0 V6 on my ford ranger. Just curious, will I have issues with the engine mounts, or will the stay the same? I dont want to deal with fabricating mounts or doing any welding...
racsan
3,397
central ohio
2.3/140-4
225/70/15-winter. 235/75/15-summer
built, not bought
I think the block casting with the mount threads would be the same, the mounts themselves would be chassis-specific but should interchange from one block to another. I think the intake & exhaust manifolds are chassis specific but easily interchange.
Ranger850
Banned... except Florida... and here soon
4,141
Tallahassee Florida
Stock 2"
Stock
Copied from link ^^
I had to swap the oil pump pick up tube and oil pan; swap exhaust manifolds, engine mounts, flex plate, intake manifold, and the oil pressure sending unit. I left the Taurus crankshaft position sensor installed in the block and used it. Everything bolted up with no surprises and I’m back to driving my truck again.
fastpakr
Forum Moderator
2,308
Roanoke, VA
Copied from link ^^
Head gaskets?
Ranger850
4,141
Tallahassee Florida
Stock 2"
Stock
Head gaskets?
Copied from same link
- I decided to try using a Taurus 3.0. I purchased a 2002 Taurus 3.0 flex fuel engine, a head gasket set, an oil pan gasket, and a water pump gasket.
EDIT : I was hoping the OP might want to read the whole thread, so I provided a link to the thread.
Ranger850
4,141
Tallahassee Florida
Stock 2"
Stock
Complete post # 1 from Ranger-Forums.com -
When my 2000 3.0 flex fuel engine bit the dust I discovered that replacement engines were hard to find. After researching the topic on these forums I decided to try using a Taurus 3.0. I purchased a 2002 Taurus 3.0 flex fuel engine, a head gasket set, an oil pan gasket, and a water pump gasket. The head gaskets are different between the two engines and must be replaced. I found it easier to pull my water pump and clutch fan as a unit and mount it to the Taurus timing chain cover after the engine was installed. I had to swap the oil pump pick up tube and oil pan; swap exhaust manifolds, engine mounts, flex plate, intake manifold, and the oil pressure sending unit. I left the Taurus crankshaft position sensor installed in the block and used it. Everything bolted up with no surprises and I’m back to driving my truck again.
fastpakr
Forum Moderator
2,308
Roanoke, VA
Right. I was clarifying, because your post didn't mention the head gaskets on the list of things you'd replaced so I was confirming.
Ranger850
4,141
Tallahassee Florida
Stock 2"
Stock
just to confirm, That wasn't MY post. I just found it in a different forum.
superj
1,344
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i wonder why you need to change the headgaskets if you are not changing the heads?
racsan
3,397
central ohio
2.3/140-4
built, not bought
I forgot about the oil pan possibility.
Ranger850
4,141
Tallahassee Florida
Stock 2"
Stock
The Ranger Gasket gives a different water flow, somehow. It either blocks or unblocks water passages that are for Fwd use versus Rwd use
stmitch
March 2011 STOTM Winner
MTOTM Winner
2011 Truck of The Year
445
Central Indiana
You can use a Taurus oil pan in 98+ 2wd FYI.
