Does anyone have this "starter splash shield"?
mc17eln
33
Diamond Bar, California
Ford Ranger XLT
This diagram is from the 2007 Ranger Workshop Manual, section Engine -- 3.0L (2V) -- Assembly:
44. Position the starter splash shield and install the bolt and the nut. - Tighten to 10 Nm (89 lb-in).
67586
I can see the benefit of preventing oil pouring onto the starter during oil filter change, but I couldn't find its part number.
ericbphoto
Overlander in development
16,350
Wellford, SC
6"
On my truck, the starter IS the splash shield.
tw205
Bronco II Rancher.
976
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
superj
2,501
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
Maybe you can adapt something from a Nissan frontier. My 01 Nissan had a drain guard on it so oil wouldn't drain down onto the starter when changing the oil
Ranger850
Doesn't get Sarcasm . . .
4,664
Tallahassee Florida
Stock 2"
Stock
found this in a different forum.
O No 3.0!
61
Knoxville Tn
Ranger xl 3.0
You should do a dry sump system with a remote mount oil filter, to keep from getting oil on the starter....
ericbphoto
16,350
Wellford, SC
6"
Remote mounted oil filter solves the problem.
BuckHunter
17
TN
Ford Ranger 4x4
I know this is a old thread but I noticed my funnel under the oil filter has fallen off. Does anybody know the part number for the bolts that hold it on. I have one that is missing thanks.
Vindictus
330
NewBrunswick Canada
ReMan 4.0 SOHC
part # F87Z-11161-AA
pjtoledo
2,911
Toledo Ohio
Fords
3.0 2.3
which bolt? one is a bolt, the other is a stud.
one of them can be either an 8mm or a 10mm.
I never had much luck keeping the starter clean during oil changes, on both the Ranger and a Taurus.
BuckHunter
17
TN
Ford Ranger 4x4
Looks like its the stud that's missing. Its the one closest to the starter would you happen to know what I need for that? Thanks
badcrc
WA
Mazda B3000 3.0
I believe they are the same thread as the exhaust manifold studs. Those are M10x1.5. I bought Fel-Pro kit ES75106 for the exhaust manifold studs, but it's like $30-40 at O-Reillys. If you go in the store there's a section with various exhaust hardware that has the same size cheaper. There's also Dorman part # 03133 studs that I think are the same size for $15. I went with the Fel-Pro because they looked better (coated).
If anyone knows where to buy that splash shield let me know, I broke mine swapping engines on my Mazda B3000 3.0 and I can't find part # F87Z-11161-AA anywhere except one online place and the picture looks nothing like that oil shield, and another place doesn't show the picture so I'm thinking it's the same part as the place with the different picture.
mc17eln
33
Ford Ranger XLT
badcrc
WA
Mazda B3000 3.0
This is from the official Ford catalog, only installed from '04 to '08. My model year doesn't have it.
https://parts.ford.com/shop/en/us/brakes/other-brake-parts/shield-splash-7881497-1?pdp=y
splash shield
Part #: 11161
Usage: 08/04/2003 - 08/18/2008, Ranger (2004/), 3.0 V6 12V OHV EFI
Section: Oil Cooler and Filter
Thanks for the link. My Mazda is a 2001 and it had it, so I'd be surprised if 2001 Ranger didn't have it. I wanted to replace mine because when I did the engine swap my starter looked like it was sprayed with bed liner. It was completely coated in oil and black grime. But now that I'm thinking about it, that splash shield must not have done too much with my starter looking like that.
Kirby N.
March Truck of The Month
