Does a 88 ranger axel easily swap into a 96ranger?
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I am at the junk yard and found a F7 axel off a 1988 ford ranger and I was wondering if it is an easy swap into a 1996 ranger XLT 2wd with a 2.3 L4
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
Uncle Gump
Forum Moderator
6,011
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Lead, Follow or get out of my way
F7 should be a 7.5 L/S 4.10 gear.
If the yoke is the same... it should bolt right up.
Rimjam
57
Huntsville,AL
2.9
Health is wealth
'88 rear axle assy is 2 inches narrower than your '96 axle - one inch on either side. Spring perches are the same, shock mounts are the same. Driveshaft U joint may have to be changed to mate to '88 diff flange. Not a big deal.
cschannuth
26
Hermann, MO
306
Expect nothing and I’m like really disappointed
If you can’t use it I’d love to have it. Let me know where you are if you don’t want it. Thanks!
Nax6401
Utah
Ford Ranger XLT
30 x 9.5 R15
I'll let you know if it doesn't fit but I live in Utah so if you are anywhere in the sounding states I might be willing to meet half way
Forum Moderator
9,491
SW Iowa
This.
cschannuth
26
Hermann, MO
306
Thanks but I’m in Missouri so that would be quite a trip.
