YungICY
- Jul 19, 2013
- 1
- Ford
- Engine Size
- 2.3
Hey guys, I've got an 85 ranger with the 2.3 that is my prerunner project truck. In trying to get the truck somewhat daily drivable so I need to "update" the ignition system. Current setup is 2.3 with a holley 2 barrel and the tfi dizzy locked out at about 34 degrees with no advance whatsoever.
If I were to pick up a dizzy from an 83 or 84 with a single vacuum advance can I run it in the following configuration? 84 electronic single vacuum dizzy, 85 stock coil (so I don't have to worry about a ballast thingy to drop voltage) and the gm hei ignition module thingy.
If I cannot do that what would be my easiest/budget friendly route to go to run a dizzy with some sort of an advance mechanism?
Thanks in advance.
Sent from my LGMS345 using Tapatalk
Thanks in advance.
