Disconnecting fuel lines for compression test '88 2.9 V6
pacificlore
San Francisco, CA
Ranger 2.9
Hey gang,
I want to do a compression test to check the head gasket but for the life of me I cannot figure out how to disconnect fuel lines to perform the compression test. To cut ignition I'd disconnect the distributor, I did this to perform a simple glove test but I am not convinced. Any help is appreciated.
Northidahotrailblazer
457
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
Just put a push button on the starter solenoid and crank it over like that. You don't need to disconnect the fuel lines or the the ignition. Just get the engine to crank over with out the key and your good (without key power the computer wont turn on so you wont get fuel or spark). Its easier to jump the starter solenoid since its on the passenger fender in the engine bay. You can watch your compression tester right as you crank it over.
Instead of a push button I've been lazy and just used a screw driver across the starter solenoid many times. A push button with clamps is the more professional way of doing it.
rusty ol ranger
2.9 Mafia-Don
7,483
Michigan
177 CID
If youre that worried about it just pull the pump relay.
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
or if you're dead set on cranking the key without disconnecting the relay just hold the throttle all the way to the floor and it will enter clear flood mode and all the injectors will stay off.
Junk Collector
Truck of Month
4,792
Rapid City SD
If he hasn't done the zip tie mod on the throttle cable, it may not be at WOT when the pedal is on the floor.
rusty ol ranger
2.9 Mafia-Don
7,483
Michigan
177 CID
Yeah i wouldnt trust that method. Stretched cable, leaky injector, etc could still cause a start.
Angie
368
Vancouver area BC Canada
92 & 83 project
4.0L 302
knock the inertia switch??
holyford86
610
Plattsburgh, NY
many
33x12.50R15
Could be a fun adventure if it isn't
