disciplerocks's 91 Ranger build thread
disciplerocks
July 2011 OTOTM Winner
53
Evansville, IN
Because Dragcar
Because wheelie?
disciplerocks
53
Evansville, IN
disciplerocks
53
Evansville, IN
Well I have some rubbing issues to address since I used an 8.8 in the rear and its a bit wider. Rolled it a bit to help and discovered some underlying cancer. Not to worried about it though considering the rest of the truck has been beat on pretty good.
dangerranger83
5.0 HO under the hood!!!
54
Lafayette, IN
5.0 HO carbed with an np435 and np208
It's screaming at me it needs boost.
Sent from my A500 using Tapatalk 2
disciplerocks
53
Evansville, IN
I'm actually working on that.....
Jay'94
4
NA
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
TRS since 2002 - NW KY
GT-40 5.0L EFI W/AC
Jay, SVT's been off the jackstands, but yeah, its spent its fair share of time on a set of stands...
SVT
disciplerocks
53
Evansville, IN
So now that I have the 8.8 in, my brake and rear antilock light is on. I tried swapping the sensor out for the one off the 7.5 with no luck.
Unplug the RABS valve and remove the light bulb. That will fix the problem.
disciplerocks
53
Evansville, IN
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
It's possible, although I'm not 100% sure, that the signal is different (tone ring has a different number of teeth) causing the rabs light, check fluid level for brake light...
SVT
disciplerocks
53
Evansville, IN
Had to grind a bit off the rear calipers. The 14s didn't like it.
Also got the brake light taken care of, and checked the CEL. Apparently my TPS is bad. Would explain the less than expected gas mileage.
RangerSVT
Oct 09 OTOTM
ASE Certified Tech
53
GT-40 5.0L EFI W/AC
Why not grab a set of 15" stockers off an explorer?
SVT
disciplerocks
53
Evansville, IN
If I would have had 2 steelies, I would have grabbed the hoof prints off the trailer when I sold it.
