"DISC BRAKE" Pedal Pad Fitment for 2nd Gen. Ranger
SCOTTY
65
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
15,604
SW Iowa
I would be very surprised.
SCOTTY
65
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
Looks interesting but would like a yes or no
JoshT
932
Macon/Fort Valley, GA
I'm going to @bobbywalter this one...
Yes...
but may require :icon_welder:
:derisive:
Due to the way they install, a tight slip on fit, if it is wider across the top I wouldn't expect it to just fit. I doubt it would take much work to modify the pedal so that it would fit though. Make a plate that is proper size for it to snugly fit onto then weld or bolt that to the existing prake pedal.
If that's the look you like, go for it. If you're after is as some sort of performance improvement (IE larger surface or more grippy) I think you could find better options in the universal stuff on flebay.
snoranger
Professional money waster
ASE Certified Tech
12,942
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Easy…. Cut the part you step on off your pedal and a donor pedal assembly…. Weld donor pedal plate onto your original. Install rubber pedal pad.
bobbywalter
TRS Technical Staff
4,088
woodhaven mi
FORD mostly
BIGGER
sawzall?
yeah...what sno said....and....i like it. maybe i should get one....mine is worn right out.....almost to a nub
SCOTTY
65
Above the equator
Ford Ranger XLT
Cologne 2.9 V6
Thanks for chiming in guys !
I don't really want to put a lot of work into it & finding a donor plate would be hard around here.
For now I contacted Auto Krafters & hopefully they will send me the 3 measurements I asked for.
I'll post them if they send 'em to me.
1 seller on ebay refused due to needing to remove it from packaging.
Thanks for the input !
