dimmer switch
killer
florida
ford ranger
I have lost the back lights for the dash, I think it might be the dimmer switch but can't find one
any ideas what else it might be, I have dome light and when started the warning lights come on
like they should
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
8,008
Butler, PA, USSA
5.0l
4”
Moving this over to the electrical section.
Dimmer switch is a up/down wheel poking out of the dash next to the switch for the marker lights/headlights.
Blown fuse, damaged wire, bad ground, bad resistor in the dimmer switch, or bulbs burned out can all be possibilities…
killer
florida
ford ranger
thanks, looked at fuses in pass side kick plate and was good,tested bulbs and all good, will look into bad ground, bought haynes book but wiring diagram not all that informetive
lil_Blue_Ford
Cut & Weld
8,008
Butler, PA, USSA
5.0l
4”
Haynes manuals wiring diagrams look like they were drawn by a 2-year old with a crayon, and are about as useful. Ideally you need an EVTM book for your model year, one of the Ford repair manuals. You can find print versions sometimes and there’s CD/DVD versions. Unfortunately I don’t have one for your model year and I know it will be vastly different from the newest one that I do have (2000).
killer
florida
ford ranger
bought an entire dash from ebay just to get another dimmer switch, swapped out and still no dash illumination
lil_Blue_Ford
Cut & Weld
8,008
Butler, PA, USSA
5.0l
4”
Seems excessive, but either the replacement dash has the same problem as yours or the wiring problem is on the truck side of the harness.
You’re going to need an EVTM for your year. That will give wiring colors and pinouts at plugs, what you should read if you probe a particular wire, etc. A factory manual for your year will give you troubleshooting information. They are largely year specific, so yeah.
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
