differential question
mossyoak03
hampton, VA
im about to change my front and rear differential fluid bc im coming up on 100,000 miles. what do you guys use to clean it out before puttin new fluid in? and also is there a gasket i need or does rtv do the job? thanks
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
I always use some cheap diff fluid to clean it out. I also use micro-fiber towels to wipe the bottom of the diff out.
The rear has a gasket. I don't know about the front on yours (my TTB front doesn't have a gasket).
Aragorn
Florida
I have used brake parts cleaner and it works fine.
I use high temp rtv for the seal. Same stuff for valve covers and oil pans, etc.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
You don't need gaskets, straight up RTV works fine.
Junk Collector
Truck of Month
4,795
Rapid City SD
x3 on brake cleaner and RTV.
exbass94
39
Guilford, CT
4.0 SOHC, 4.0 OHV
For the front diff, you can't really clean it out at all, unless you feel like disconnecting the axles and driveshaft and dropping the whole diff out of the truck. You just have to suck as much fluid out through the fill hole as possible and refill with fresh fluid.
Sasquatch_Ryda
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Never seen a ford rear end with a gasket, its got RTV on it from the factory.
As for cleaning it out, I usually just give it a good spray with some brake clean.
mjonesjr
Firefighter
13
Salem, IN
They may not put the gasket on there from the factory, but the gaskets on the rear sure do make it easier to clean off if you ever pull the diff cover again.
For the gaskets only costing $5 at your local auto parts store, I will put a gasket on mine.
Junk Collector
Truck of Month
4,795
Rapid City SD
I have not seen a gasket on an axle that's never been open, but you can buy gaskets for them. I got one from Checker for my old 7.5.
4x4junkie
583
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Drive the truck at freeway speed for about 20 miles or so with the hubs locked (t-case in 2WD) before you suction the oil out of your front diff. This will get any crap inside there suspended in the oil to be sucked out with it. This is about as good as you'll be able to do without taking the whole thing apart like exbass mentions.
mossyoak03
hampton, VA
thanks alot guys
