Differential gear oil change
LIMA BEAN
140
ALASKA
You're very welcome and we appreciate newcomers, the amount of knowledge here is mind blowing and has been since the beginning. Keep us posted on your project.
lil_Blue_Ford
6,129
Butler, PA, USSA
4.9L
My 95 F-150 called for 75-90w if I remember right for both axles. Since it’s my hauler and I built it to be able to plow snow, I put I think it was 80-140w in. Front is an open diff and rear has a lunchbox locker so no friction modifier. FYI, some of the new synthetic oils don’t require an additional friction modifier. My green Ranger is getting a limited slip rear and I’m going with a full synthetic that doesn’t require extra friction modifier, says it has it in it
gaz
656
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
That is my favorite truck body style.
mikkelstuff
468
Brighton, CO
I have in the past drained a differential (or manual transmission), refilled with cheap synthetic automatic transmission fluid, driven a few miles and drained again. This was to help clean out that original lube and goop before refilling with synthetic. The synthetics are so much better in my experience.
sgtsandman
Aircraft Fuel Tank Diver
12,646
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
If nothing else, they pour easier than standard gear oil does. And stinks a lot less.
