Difference between Clutch Master Cyl/Line - '89 Vs. '94
DPDISXR4Ti
New member
New York
I'm doing a clutch job on the '89 and because I had to cut the line I figured I'd just replace the master cyl as well. I was at the junkyard yesterday and came across a '94 that had a relatively new master cyl and line, so I grabbed that. Now I'm seeing that '89 - '91 seems to be a different part from '92 - '94. But is it? Or is there some tiny difference that won't really matter from a practical standpoint. Yes, no, maybe???
One other thought.... I see that the pedal box is different for the same range of years specified above. Could I put the '94 pedal box in a '89? Might there actually be some benefit to that?
Rock Auto 5% Discount Code: 32B05A80BF19AF Expires: July 1st, 2020
Well-known member
1,655
The quick connector for the slave is different, so it won't fit, which is the big deal unless you want to change the slave, lol
I think you need 1991 or earlier quick connect
As far as the clutch pedal assemblies, they are different and not interchangeable
I think, and stress the "think" part, they break down like this:
1983-1987, Gen 1
1988, a 1 year part
1989-1990, might be 1989-1992, Gen 1.5
1991-1994, might be 1993-1994
1995-2011, there seems to be a break point at 2006 but I think these years are interchangeable
The problem you can run into is that Ford of didn't always change specifically by Year, they used what they had until they ran out and then used the new design, you run into this with all car makers
snoranger
Forum Moderator
ASE Certified Tech
2,897
Jackson, NJ
'79,'94,'02,'17
All Fords
The quick connector is different.
Denisefwd93
Well-known member
62
South East PA
Get new pre bled set up l, why would you even mess around with old parts with all the trouble transmission in & out is
Forum Moderator
3,172
SW Iowa
1983-1988, Gen 1
Neither here nor there for the OP but '88 clutch pedal was a 1 year part. It had the switch that slid on the pushrod like the later ones but used the same potmetal die cast bracket and brake pedal as the 83-87's. The clutch pedal was bent/shaped very differently though.
Well-known member
1,655
Good info, I changed my post to reflect this
DPDISXR4Ti
New member
New York
I already have the new slave, and just now checked to make sure I got the right one. I did, so I guess I'll be sticking with original spec parts. FWIW, it's spec'd as '88 - '92.
Off I go now to order the correct line.
Thanks for the input.
DPDISXR4Ti
New member
New York
Why would you need to R&R the transmission to replace the clutch master cylinder?
bobbywalter
TRS Technical Staff
976
woodhaven mi
FORD mostly
BIGGER
sawzall?
Just pull the pin and switch the line.
Denisefwd93
Well-known member
62
South East PA
You don't really think you get away with just master cylinder do you?
DPDISXR4Ti
New member
New York
Not sure the context of your question. The transmission is already on the ground. New clutch and slave already in-hand.
DPDISXR4Ti
New member
New York
Right, that's my likely plan. But from what I've read it's all but impossible to replace the line with the MC in place and not introduce some air, so it seems best to pull the MC even if the original goes back in.
bobbywalter
TRS Technical Staff
976
woodhaven mi
FORD mostly
BIGGER
sawzall?
Where are you located?
I make a pin pusher and do it.
It's always a kick in the booty to bleed....
Maybe I am just lucky.
Junk Collector
Forum Moderator
573
Rapid City SD
I usually get them on the 1st or 2nd try, I just hate the bleeder valve though. Why could they not make it maybe an inch longer and with a normal bleeder nipple on it so I can put a piece of clear tubing on it and a wrench at the same time????
Well-known member
1,655
You can make an air bleeder with clear tube connected to a funnel, funnel needs to be raised above slave, and hose does not technically need to be clear, lol
Attach hose to open bleeder put some fluid in the funnel
Push down clutch(or brake) pedal and any air is pushed out, hold pedal down to let air bubble up to funnel, then let up on pedal and fluid, not air, will be sucked back in
Repeat as you see fit
