- Jun 29, 2023
- 8
- Oklahoma
- Ford Ranger
- Engine Type
- 3.0 V6
- 2WD / 4WD
- 4WD
94 Ranger, 3.0, 4WD. Dana 35. 3.73 7.5" ~330k miles
Earlier this month, my truck started making a rhythmic "thud" sound. Lifted the rear end up and drove it and sure enough, it was coming from my diff. I'm told this could be the pinion bearing, which makes sense to me because there were a lot of metal shavings on the ABS sensor when I replaced it the month before.
The fluid is 3 years old, and it's had about 25k miles since then. The ring gear has been missing a tooth since before I bought this truck 5 years ago, but I haven't had any noticeable issues while driving it. However, my thinking is that if I'm going to pull the ring and pinion out to replace the bearing, I may as well replace those too while I'm in there. That said, I've never serviced my diff beyond a fluid change. I'm certain I can figure it out, but I won't know for sure what else is damaged and what's not. The whole differential might need to be replaced for all I know.
On the other hand, I could just go to the Land of Misfit Parts and pull a rear end. I'm uneducated in this area as well, as once again, I don't know how to tell a good one from the bad even if I pull the cover off. But this may be the simpler (and possibly cheaper) route. Additionally, I've been told that the 8.8" gear is more reliable than the 7.5". Is this true?
Which option do you folks recommend?
Do you have any advice on what to look out for?
Thanks
Thanks
