Diesel 2003 Ranger
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Hey,
Looking for info about the new crate motor from Cummins !
The engine is a R2.8L, 4 Cyl, turbo, high pressure injection, AND I hear that it may come with an install kit of pieces to make it work and a separate kit for emissions based on state !
Weight seems to be lower for a Cummins Diesel, 560 lb, size small, should fit.
Thinking what trans and will my AtlasII transfer case fit ?
Trying to get some info before tearing in to the Ranger.
Ltr
Rock Auto 5% Discount Code: 81874766E40C6A 5th, 2022
griz700rocket
Dirt for Days put one in a jeep. Look them up on youtube. Guy is kinda quirky but some good info on it anyway.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Watching the vids on U-Tube gave me some ideas, maybe a Jeep Trans could work implace of the Ranger 5-sp, also a GM automatic could work too. Now to see if I can get an auto to bolt to my Atlas II T/C.
I put my name on the call list for a new R2.8 Cummins, need to get going to get a parts list and an installer !
Why do I do this ?
Ltr
griz700rocket
For crawling I can see it being good with all that low end torque. Personally the way we wheel something that revs faster is a better option. IMO diesels are great for towing but too heavy/slow reacting to good in a wheeling rig.
Scrambler82
11
SoCal
Ford/EDGE
4.5" SL
WWWhhhaaattt !?!
33 x 12.50
Watched it, gave me some ideas about which trans to use and about adapters available.
I think it would make a serious off road engine, yes it will not rev up as fast as a gas V-8 or V-6 engines but better than some 4-cyl engines. you just need to get the best trans/gearing for the application.
Remember the R2.8 Cummins can put out up to 200 HP and 380 ftlb of torque without a lot of tweaking.
I am perusing it but first I need to know if it will be considered a replacement engine for a Ranger in SoCal, then I can go after the trans/adapters and miscellaneous items.
Thanks for the replies.
