Bruts is with the program. good man , imposssible today with out.
Fluke 99b 100hhz
fluke 97 50 hhz
todays standard that is slow
AES wave form manager/laptop
OTC perception
FOR the home mech. there several great choices
Built in database perception. snap-on. and others have it.
THIS is cool.it has a the wiring diagrams and pin out numbers.. system description.for most vech. and components.
like for ranger 2.9 TPS
describe the system
show you a wiring diagram and colours just for that curcuit
pin out numbers
graphing meter or scope, will work on any electrcal system in you house
once you have one. all kind of avenues open up.
OTC perception remans $500 second hand cheaper
With inductive mili- amp pick-up add, to you system
a hole, nother world, open up.
check this out.
With inductive pick up.you can measure amps on any electrical device
From you bed lamp to you vech.
On fuel pumps you see commutator wave form. if one is bad you can see it
Going on a long trip.? I'll tell you if theres a chance of that motor landing on a dead spot.. that cool.
after throwing hundreds of dollars at your car. It won't take long to pay one off
IT will follow you your hole life.and you will be in tune with the modern world.
that cool,
