Diagnostic codes
coolbrze
Truck has been shaking/sputtering when under accelleration & the check engine light came on. I pulled the codes on the truck below in my sig & got:
P0171 - System to lean Bank 1
P0301 - Cylinder 1 misfire detected
What does this mean in English?
mentalbreakdown00
8
Tallahassee, Fl
Jeep
Ok it means the computer has detected a missfire on cylinder one and that the oxygen sesor on that bank thinks it's running to lean. Now I would check for a vacuum leak, check the plugs, make sure you have good spark, and let us know whats going on.
coolbrze
Is there any thing in specific that I should look at to see if there's a leak? I checked the PCV and other hoses and didn't see any dry rotting or cracked hoses. I pulled the plugs & cleaned them, but the problem persists. How do I check for good spark or should I just replace the plugs?
BTW - which is cylinder 1, it's an inline 4?
ForOffRoadDriving
18
HIGHLAND, MICHIGAN
FORD
3.0L
it will be the cylinder closest to the front of the truck. check the resistance of the spark pulg wire on cyl 1 to the other 3 cyl using a volt meter. you may have a bad wire or one that has built up a high resistance over time.
naford
12
Pull the spark plug and see what it looks like.
coolbrze
Is the correct way to do this by grounding 1 volt meter tester to the engine block, then touching the other to the spark plug wires, 1 at a time?
coolbrze
They all showed about the same reading, any other ideas? May just have to take it to the dealership... :(
No members online now.
