Dent repair options
Ozuye10
VA
Tried the suction cup from Harbor freight and didn’t work. I’m considering getting a dent puller from Amazon or something. Anyone use these successfully?
Gliston Auto Dent Puller Kit - Adjustable Golden Dent Remover Tools Paintless Dent Repair Kit Dent Lifter Puller for Car Large & Small Ding Hail Dent Removal https://a.co/d/enZZQgf
dvdswan
1,383
Seattle, WA
Ranger XLT 2WD
Where is the dent?
If its in a spot where you can put a deflated football and add air to pop it out that might work. If there are any creases in the metal it will make it harder to pop out and the creases may stay depending on how big they are.
Ozuye10
VA
Blmpkn
2,621
Southern maine
Ford ranger
2.3 EcoBoost
2.3
2.5" level
Oof.
What's a straight fender cost? Better off to just to that honestly.. You'd need a weld on stud puller for a lot of that and then a bit of cheese work and then paint of course..
dvdswan
1,383
Seattle, WA
Ranger XLT 2WD
^^^This. I'd look at the junkyards and heck you may get lucky with a color match.
superj
860
corpus christi, texas
ranger edge
V6 of power
none
none
235s
Grew up in the 70s, 80s, and 90s
that is not an easy fix. i pictured a little dent in a flatter panel but thats a serious hit there. someone backed into it or you hit a pole while backing up?
rumblecloud
636
48022
Ranger Splash
1-1/2 inch front leveling
Stock
P235/75R15
What's the worst that could happen?
I just picked up a left front for $35 at the u-pull here in the thumb - in excellent condition.
Better off to just replace the fender when you consider the time and money spent to repair the original.
Unless you just want an excuse to go buy more tools: "Honey, I can do this myself if I had the right tools...
I use that one all the time. 😬
Ozuye10
VA
Yeah I’m just going to replace the fender. I’ll look around for a paint match but if not, I’m sure a can or two isn’t crazy priced.
