Dead short
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Hey TRS'ers, I wonder if you guys could help me? I went to start my Ranger yesterday and no way. The battery was totally dead. Odd, it worked fine the day before. Hooked up jumper cables and it was arcing as though the polarity was wrong but wasn't. So I assume I have a shorted out wire somewhere. :icon_confused:
Before I start chasing through a quarter mile of wiring or replacing harnesses, is there anyplace in particular I should look? Have any of you guys had this happen to you?
Thanks in advance.
crusin93
4
Maryland
First off disconnect the +/- cables from the truck to the battery, then put jumper cables or charger onto battery. If an arc occurs you have a short in the battery. If not work backwards from the pos lead. A likely short can occur in the starter solenoid or starter itself. Hope this helps!
feellnfroggy
28
Knoxville, TN
My battery went 'dead' all of a sudden and i couldnt figure it out. Two starters later we realized it was the battery, a slice in the positive wire allowed corrosion into the wire and prevented good energy transfer. Start at teh beginning,(your terminals) and methodically, slowly work outward.
GoodOld85BlueBalls
167
Denver CO/ Natal, Brazil
FORD/FORD
3.0Powerstroke/3.5 EcoBoost
The last time I had a short in a Battery, it blew up when I hooked the jumper cables to it. Be mindful that it is always best to hook the jumper cables to the bad battery first, then land them on the one in the running vehicle. Always hook up the positive first and land the ground on another part of the vehicle other than the battery.
I hate my acid washed coveralls. :D
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
Thanks guys. I didn't know where to begin.
LearjetMinako
12
Moore, OK
2.3L 140ci
Have had that happen before. Went to Wal-Mart one morning for storage bens. Got done shopping, and to the Ranger to head back home. Turned the key and all my gauges went reversed. No click, no power, no light. Got a jump and head straight home. Tried again once I got home, same results.
Word of the wise. Batteries do not have to give an indication of them dieing. And should be tested annually or every 6 months if they are older than 3 years old.
prerunner
Surrey, BC
Blue oval!
4.0, 4.0
The "Bad ground issue" thread below this is pretty similar to my issue. Thanks again for your help guys.
