2.3L ('83-'97) Dash warning lights don’t work
mdiiorio
5
Atlanta
Hello,
So I just replaced the cluster in my 1995 Ford Ranger, the new cluster is a 1997. I noticed that when I put in the new cluster certain lights stopped lighting up. This would include the ebrake light, the abs light (that was on with the other cluster), the check engine light, and others. The only lights that actually light up when I turn the ignition for the test is the battery light and airbag light. All other lights work perfectly and all my gauges work great. Anyone know why this might be?
Thanks,
Mike
gaz
761
Wa, Bremerton 98310
Ranger 5" (1½" Hiryder/3" body), BII 4" Procomp
Ranger 5sp, BII A4LD
Ranger 32"/4:10LS, BII 33"/3:73LS
Hello,
Perhaps check the bulbs again ..)
tomw
47
lima bean
vertical and above ground
Bulbs or the printed circuit on the back of the cluster is different. The sockets that hold the bulbs make contact with the circuit when they are inserted into the opening and twisted CW. If there is corrosion or wear, poor contact can be another cause. Final cause would be the actual connectors that connect the cluster to the wire loom. They can be a bit finicky when inserted, and again, make poor contact.
I would first compare the circuit layout to the original. It could be different. You can trace back from the individual bulb to the point where the truck wires connect to see if the bulbs in question match the original layout. If they do match, it is likely bulb/socket/connector problems, otherwise it is going to need surgery.
tom
scotts90ranger
5,589
Dayton Oregon
2.3 Turbo
I just did a tach cluster swap on my '97 and at first the left turn signal indicator didn't work, a couple days of driving around and it started working again...
8,412
1995 had a few different wires than 1996 to 2003
You will need to re-pin most of the wires, they are all there just in the wrong spots
If it looks like too much then look for a 1995 cluster and sell the 1997
Below are the diagrams for 1995 and 1997 Ranger clusters
scotts90ranger
5,589
Dayton Oregon
2.3 Turbo
So the check gauge lamp is just connected to the slosh module? Interesting, that's why it goes on at just a couple gallons of fuel left... happen to have the one for a '00?
8,412
Should be same as 1997, 1996 to 2003 are plug and play
Rick W
October Truck of The Month
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
