dash lights
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Disconnect your battery for 30-45 min, hard reset on computer, if it comes back then have the code pulled, you may want to pull the current codes before you reset.
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
its looks like you have no oil pressure.
A check Gauge is like is just as it says, on E on fuel, H on temp or no oil pressure.
I would look at the oil sender its could be at fault or there is really no pressure
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
Good eye, didn't spot that, but the oil pressure sender for the gauges is a different one than the one for the computer.
ronclark
Ham Radio Operator
25
Woodland, WA
95 4.0 with 93 ECU
I know there is two Temp senders, I did not know the ECU had a oil pressure sender.
I know my 4.0 had to oil senders one for pressure and once for level, but both go to the gauges
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
Yup, it's your oil pressure gauge. Find out why she is reading zero( IE broken wire, or bad sensor). If you have an aftermarket gauge just jump find a correct resister and go to any ground point.
Lil-Pony
5
San Antonio, TX
Take a Guess
2.8 soon to be 4bt
wellllllll,
normally there is a sender, variable resistance, for the gauges and switch for the ecm so the computer just know that their is oil pressure, it doesn't know how many lbs, it just knows that there is oil pressure
4banger_ranger
Kingsland, Ga
2.5L
when ever im driving down the road and shift into 3rd gear the needle jumps 3 or 4 times and then drops back down
