Dlillie87
- Oct 14, 2021
- 7
- Florida
- Ford/Ranger
I'm still trying to figure out the best way to accomplish this and have everything work properly. I've been thinking that just mounting the 44 into the 28 mounts, trimming the axle shaft, and moving the upper spring mounts away from the frame was the easiest method. Someone on FB suggested this bracket kit.
Has anyone used it on a 1gen ranger? Will I still be able to install skyjackers 4 inch lift kit?
Dana 35/Dana 44 Conversion Beam Brackets
These brackets were developed to allow vehicles equipped with the Dana 35 TTB, to convert to the full size Dana 44 TTB. They also feature a second pivot location to allow the use of Dana 35 TTB's. The entire weld it yourself kit contains 20 pieces. 16 pieces are laser cut, .25" steel that are...
www.gofastexplorers.com
