Dana 35 - knuckle/spindle stud thread pitch
manley
5
Richmond, IN
2.9 swapping to 4.0
Wut?
Real quick, what is the thread pitch for the studs connecting the spindle to the knuckle on the 93-97 Dana 35? Thanks!
Curious Hound
Formerly EricBphoto
TRS 25th Anniversary
18,803
Wellford, SC
6"
Why didn't you ask me about a month ago when I had it apart? It's common pitch (not fine thread). But I don't know the actual size. Somewhere in the neighborhood of 7/16" or 10mm or 3/8" or 8mm.
Yup. I'm helpful tonight.
lil_Blue_Ford
Cut & Weld
7,321
Butler, PA, USSA
5.0l
4”
I did remember at one point. Even have a bag or two of NOS Ford replacement studs somewhere. They’re probably keeping my spare CB antenna mounts company since I haven’t seen those lately either…
20,146
SW Iowa
I just pulled mine off today. I noticed as the nuts were stuck in the socket I could tap them on the tie rod adjuster sleeve and then thread the nuts onto the bolt to pull them out of the socket.
They are metric, takes a 15mm socket.
Curious Hound
Formerly EricBphoto
18,803
Wellford, SC
6"
I thought I remembered using a 15mm socket. But wasn't sure if it was the right size or the closest metric equivalent to a standard size. If they take a 15mm socket, I'm sure they are m10 x 1.5 threads.
By the way. The original nuts are self-locking with a deformed thread inside. But I use blue Loctite on them anyway.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,575
woodhaven mi
FORD mostly
BIGGER
sawzall?
3/8 - 24
but easy to mix up with m10.
manley
5
Richmond, IN
2.9 swapping to 4.0
Wut?
LOL … I am trying to run a thread chaser down them and it isn’t going well… I started questioning if it is metric or not.
manley
5
Richmond, IN
2.9 swapping to 4.0
Wut?
3/8 - 24
It says 80-92? Did it change to metric in 93?
snoranger
Professional money waster
ASE Certified Tech
14,519
Jackson, NJ. And Manahawkin too.
'79,'94,'02,'23
All Fords
2.3 EcoBoost
Stover nut.
Curious Hound
Formerly EricBphoto
18,803
Wellford, SC
6"
bobbywalter
TRS Technical Staff
Ugly Truck of Month
5,575
woodhaven mi
FORD mostly
BIGGER
sawzall?
count the threads and try a m10 nut.
i used k truck studs on my ttb 35....same as the ones on my drum brake 44 in the bronco when i tried to use k20 spindles and brake plates....
that didnt work out the way i had hoped for.
snoranger
ASE Certified Tech
14,519
'79,'94,'02,'23
All Fords
2.3 EcoBoost
20,146
SW Iowa
15mm was the only socket in my trusty socket set that fit them. I had to buy a special 15mm impact socket because my 3/8 impact sockets skip that one.
scotts90ranger
5,303
Dayton Oregon
2.3 Turbo
It's Ford, I don't put it by them to use a 15mm hex on a 3/8-24 thread... but that said I do have a knuckle in my shop without a spindle on it and it is definitely 10mmx1.25 took the thread gauge to it and everything, a 3/8-24 nut did not thread onto the stud.
Rick W
October Truck of The Month
25th Anniversary Merch
