Dana 28 to Dana 35
RumPunch
Law Enforcement
752
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
If I was to go to a salvage yard and get a set of axles, what is required on the front to swap to a 35? Carrier obviously, are both housings necessary? Just driver side? Axle shafts? Knuckles?
FYI pic is just for reference of donor BII front end. Not a D35. Thanks.
Junk Collector
Forum Moderator
3,641
Rapid City SD
You need everything. The only part from your current axle that you could reuse if you want to is the radius arms. You will also need the steering linkage off the donor, or new parts- D35 linkage is wider.
lowspeedpursuit
84
DE
B2300
IIRC you need the whole assembly, both beams. I've personally held both knuckles, and they're different. Pivot brackets and radius arms should cross. D35 driveshaft needs to be ~2" shorter. D35 swaybar end links look longer.
RumPunch
Law Enforcement
752
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
$250 per axle seem high to y’all?
Thanks exactly what I needed to know.
Forum Moderator
13,250
SW Iowa
Mine was $75 with a pallet... but your results may vary.
Crawl the yard and try to convert to manual hubs before you check out.
RumPunch
Law Enforcement
752
Walkerton Va 23177
Ford Bronco II
3"
31x10.50R15
All 2/3 I saw yesterday were manuals.. 1 2 door explorer, one 4 manuals and 1 EB autos. But they want $250/axle..
Forum Moderator
13,250
SW Iowa
Maybe buying them a half at a time will confuse them? :dntknw:
Junk Collector
Forum Moderator
3,641
Rapid City SD
$250 could be a decent deal if it comes with good brakes and manual hubs. Pass if it needs a bunch of parts. I am spoiled with complete parts trucks for a couple hundred bucks though.
scotts90ranger
2,658
Dayton Oregon
2.3 Turbo
Also know that you will likely have to shorten your front driveshaft an inch... D35's were only in rigs with 1354 T cases that have a different front output so you can't just use that unless you grab a T case, if electric case should bolt right up and the newer front shafts are nicer with a dual cardan joint at the case...
SenorNoob
274
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
There is a factory shorter front shaft from I think a TK4. Probably hard to find. I got lucky.
4x4prepper
213
Atlanta
$250 hub to hub with the roll bar would be a good price, especially if it came with 4.10s and reusable calipers. Try to get ones where you can easily turn the bleeder screw using a 1/4" ratchet.
Carlisle Truck Nationals
Join us at the Carlisle Truck Nationals for the 40th Anniversary of the Ford Ranger.
