well thats exactly how a couple supposed desert guys have been telling me. but it seemed to me that it would be more of a technical thing. than just pulling the bottom joint out till its looks good. i realize it more to it than that but thats how it sounded to me wanted your in put thanks .
Not much technical to it. Just measure block and adjust. This way it's going to be right every time. Coil spring height varies so much that it's hard to guage what is the right measurement. Doing it the way i posted is going to get the best results and get you closer to the 0° bushings that is desired.
As an example on my current D35 beams the camber is all messed up. I have the 1-3.75° bushings. One side is at +3.5° and the other is at -3.75°
This could attribute to me running 4" drop brackets and 3.5" of spring lift.
Now if I was to put the stock brackets back on and do a cut and turn on the beams I could get it back to +1° on both sides.
I doubt the 1.125 and .875 measurements would get me to that point.
There is a reason you don't see measurements posted. There isn't any real numbers to go by. Not likely to have the same geometry and parts as the last guy.
Take it for what it is. It's not as easy as just pulling the joint out xx" and it will work for you.
