D35 Chrome Moly outer axle shafts
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
Bet you had this failure due to spitting a cap. Try using full snap rigs or tack welding the caps and upgrading to Spicer 5-760X u- joints.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
It was full circle clips. I think I'll weld them next time.
Todd
HCT
12
Troll land
BIITR
Solid Axle Swap 4x4
Ya even when I used full clips the cap still ended up spinning and egging the yoke. After I started tacking them is when I stopped the problem of spitting caps.
-Nathan-
39
Saskatoon, SK, Canada
HO 5.0 / 7.3 PSD
do you guys use 1 or 2 tacks, and does it not affect the needle bearings in them?
wahlstrom1
J-man HD Mech
2011 Truck of The Year
Forum Staff - Retired
21
Edmonton Alberta
...and the supercharged 4.0L and 35's had nothing to do with it? Lol, tack them and hope for the best!
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
NO WAY ! Has nothing to do with it !!:yahoo:
Andres629
11
Saskatchewan!
2.9 screamer
It was probably all the gnar terrain at the WEM. Have you SEEN that parking lot?! lol
In all honesty, got a buddy running some chromo shafts on his rig and hasn't had a problem yet. He is still only running a built 2.9 and 33's, but it's locked and all. Used to have problems breaking axle 'til he ran chromo ones... I just don't know if they're the same ones as that or not. :dunno:
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
Does he have a SAS or is it TTB ?
Andres629
11
Saskatchewan!
2.9 screamer
TexasDuck66
July Truck of The Month
