2.3L ('83-'97) Cylinder 3 and 4 won’t fire
gbcooper
Atlanta
Ranger 2.3
I have an 85 ranger 2.3 Lima with EFI. I’ve had the truck sitting for a few years so I’ve been trying to get her going again. I did a top end rebuild because I suspected leaky valve seals and resealed her. It ran like a misfire with lots of smoke beforehand but there was evidence that #3 had massive head gasket blowout when I disassembled it. I’ve put it all back together now but I can’t get #3 or #4 to fire.
I’ve checked for spark and the valves. I pulled off the injectors and put 12v to them and they worked fine. When I run the truck, it misfires bad and I know it’s those 2 cylinders because if I pull the wires off the distributor nothing happens. Any ideas? It has spark and a working injector.
My only theory is that the 2 injectors aren’t grounded or the wires are corroded at some point in the harness and shorting each other out. I have a multimeter and a wiring diagram so someone please throw me some suggestions. How do I test the injectors with multimeter? What should they read?
Also, in the back of the Haynes manual I found the diagram and it looks line #1 and #2 are grounded together while #3 and #4 aren’t. Is that the culprit? I haven’t traced the wires back yet since it’s night time here but if anyone else has had this issue or know what’s going on - please let me know.
RobbieD
2.9l Mafia
3,790
Georgia
I'd do a compression test first; it's not clear if you fixed the "massive blowout" on #3. Without enough compression, spark and a working injector won't fire the cylinder.
gbcooper
Atlanta
Ranger 2.3
What size adapter do I need? I actually have a harbor freight one but none of the adapters fit or threaded.
Also, when I had the head off I took the time to clean the surface real well. Albeit I didn’t have it machined. I let about half an inch of atf sit in each cylinder to gauge the rings and it took about 3 days to show the pistons again. I figured they’d leak differently if 1 was crud.
RobbieD
2.9l Mafia
3,790
Georgia
I'm not sure what size adapter you'll need.
It just makes a lot of sense to confirm the compression (as it's not difficult to do and you did have a head gasket issue), before you start chasing other things.
scotts90ranger
4,885
Dayton Oregon
2.3 Turbo
The spark plug threads are standard 14mm, you might need the longer adapter on there to work.
all 4 injectors are powered at all times with the key on, the computer only has two injector drivers in it that trigger cylinders 1 and 4 at the same time and cylinders 2 and 3 at the same time, IE batch fire... If you look at the turbo swap area there's a I think '91 Ranger engine wire harness drawing, the injector wiring is the same even though in '91 a Ranger had distributorless ignition and a mass air flow sensor instead of a MAP sensor.
I would check the power at injector 2 and 3 and continuity between the signal wire on those two injectors and the pin at the computer.
gbcooper
Atlanta
Ranger 2.3
I’ll do a check when I get home just to make sure. Based on these responses and a good sleep - I doubt it’s the wires. I’ll report back with a compression test
TexasDuck66
July Truck of The Month
