rfl
- Mar 17, 2011
- Reaction score
- 0
- Location
- Utah
- Make / Model
- Ford
- Engine Size
- 4.0
- Manual
Been dealing with a bouncing speedometer in a '93 Ranger 4x4, 5 spd, 4.0, since I bought is used about 4 years ago. Every now and then I try something new to see if I can fix the problem, however so far no luck. I got thinking about how the cruise was also surging so figured the next option was to replace the speed sensor but that resulted in no change.
What I have done, in order:
Replaced the gear at the end of the speed sensor (about 10k miles ago)
Replaced the speedometer cable with a new OEM (about 7k miles ago)
Replaced the speedometer with a used head, still broke, just different bounce patters (about 6500 miles ago)
Replaced the speed sensor, verified the gear was in good shape (today)
I gave the truck to may 16 yo, so I would very much like to get the speedometer and cruise working properly. Other than trying another speedometer or having the existing repaired, which I am not sure will help since the cruise also surges, is my next option to replace the gear inside the transmission (looks like a ring)? If so, is this something that can be replace without dropping the trans or trans oil?
