eightynine4x4
- Oct 15, 2020
- 178
- New York
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 2.5" Suspension
- Tire Size
- 31 x 10.5 x 15
1989 2.9l 4x4 automatic
Long story short: I’ve got a bad connection from Y pipe to cat.. the old Y pipe has rusted away a little bit at the very end and so the gasket doesn’t even really seat since there not enough metal around it.
So I have a leaky connection there, and it’s visibly releasing some pre-cat exhaust.
Also, I can’t replace my whole Y-pipe without shutting down the truck for a couple weeks and working on removing the left exhaust manifold. I already replace the right and it was been tremendously precarious and a huge waste of time. Almost had to ditch the truck project. So I’m not going to commit to fully replacing the Y pipe any time soon because I am not touching that left manifold right now.
A compromise..
what about buying a new Y pipe and cutting it like a foot upstream from the cat, and replacing just that section of old Y pipe? Would a dual clamped sleeve around the y pipe(s) juncture be enough to seal the new segment to the old Y pipe? Talking about using a short strip of tubular metal that barely slides over both now exposed ends and using two u-clamps, one for each half of connection.
Sound like a terrible idea for any reason? In the distant future I could even use the rest of the new Y-pipe once I removed the left exhaust manifold. It would clamp together prior to the cat in the same fashion. Might look a little weird but if this sets me up to stop the leak then I’m happy. Wouldn’t care about always seeing a union there in future too.
A compromise..
