Crankshaft pulley or "Harmonic Balancer"
Dangeranger3
Peoria, IL
420
I don't have anything to add, but Good Luck!! I'm anxious to here what the hitch here is.
Acepilot1023
East Coast USA
2.9L
It was easy to get off in the end. I borrowed one of the Advanced Auto harmonic balancer puller, which was much heavier than my own, coupled with plenty on penetrating oil and a good strong 3lb hammer. :yahoo:
DPDISXR4Ti
33
New York
Bumping this older thread as I'm also struggling with removing the harmonic balancer. As you can see, I've left the main center bolt in place, but unscrewed about a 1/4" so that it's just working as a pivot point with the harmonic balancer puller using two or three of the 8mm threaded holes as puller locations. That's what I already tried, but perhaps I need to try harder.
Alternatively, what about using a slide hammer with the 8mm fittings? I've already removed the radiator, so I've got clearance to whale away as needed.
pjtoledo
2,965
Toledo Ohio
Fords
3.0 2.3
post #4 has a good idea.
get lots of tension on the puller then whack the center bolt with a normal sized hammer.
that will send a jolt that allows the pully to move a tiny amount, only a couple of thousandths.
tighten the wrench, it will not turn much. hit it again.
rinse & repeat, it may take 20-30 whacks before you can visually see it move.
slow process indeed, but it does work.
it once took me 30 minutes to pull a rusted pulley off an engine with this method.
back to nap time now
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You would die from exhaustion before you would remove it with a slide hammer.
I've always used a steering wheel puller. Use the threaded holes in the balancer... remove the washers from the crank bolt and just pull it off.
2 or 3 jaw pullers usually damage things and are a train wreck here for this task.
DPDISXR4Ti
33
New York
And indeed that's what I did....
Uncle Gump
Token Old Guy
13,457
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Gotta love it when your plan comes together.
