white92ranger
- Jun 14, 2022
- 0
- Minnesota
- Ford Ranger
My 92 2.3 ranger developed a weird sounding rod knock and had brass colored flecks in the oil, so i yanked the engine and pulled off all the main caps and rod caps to check the bearings. only thing i found was a score the 2nd main cap bearing which didn’t explain the rod knock or brass flakes…I figured id pull the thrust bearing to check it and this is what i found…
I assume this is the source of my rod knock and brass colored flakes, right? what would cause this to happen? all the other bearing looked great, including the 2nd half of this bearing.
