2.5L ('98-'01) Crank no start
TimY
Austin Texas
Hello. I have a 98 Ford Ranger 2.5L manual trans. About a month ago got in it one day and it would crank, no start. I have replaced the fuel pump and crank position sensor and a new computer. The fuel pump relay only has constant power on one wire. I have read articles that the second wire at the relay will have power with the key forward. No dice. I also checked power to the inertia switch and no power there either. Any ideas what I should check next? I appreciate any advice.
MikeG
751
central Texas
B4000
2"
235/75r15
Did you check all the fuses? Mine blew a PCM fuse, would crank but not start. Since it would crank I didn't check the fuses till after getting it towed home.... grrrrrrr......
TimY
Austin Texas
Yes sir. I checked every single fuse. All good.
koolhandlinc
Tulsa
2.3
Any luck? Update?
