- Aug 31, 2016
- 2
- Ford
- Engine Type
- 3.0 V6
- Engine Size
- 3.0L
- 2WD / 4WD
- 2WD
- Tire Size
- 235/75/R15
- My credo
- Work Smarter not Harder
After swapping from belt to electric cooling fan, the fan stays on even while the engine is off. I originally had the ignition wire from the kit spliced into the 50A ignition fuse in the engine compartment fuse box. Any suggestions on where to splice the wire on a "Hot in run only" location? ('99 XLT FlexFuel w/air conditioning). The fan kicks on when up to temp and when the a/c is on, it just stays on until the engine cools down and I'd rather not have to wire in a shutoff switch.
