- Jun 2, 2012
- 8,369
- canada
- Ford
Yes, it would lean in that direction.
You should see where intake manifold gasket was leaking coolant, it can only leak at the 4 corners assuming lower intake casting is not cracked at a coolant passage
A head gasket can just leak coolant out around its edges, its unusual but not unheard of
From the picture the leak had to have been spraying out, so under pressure after warm up, to get that much coverage in the valley
