Coolant gauge stuck at cold
soggybread
BC
Ford Ranger 2.9
Hello, recently bought my 1990 2.9 coolant temp stuck at C & not getting very hot air into the cabin. Blows warm but not hot. Any help is appreciated!
Brain75
984
Colorado
215/70R14
2.9's (especially the older ones) are notorious for cracking heads, it is highly likely that the PO put in a low temp thermostat to try to avoid the issue... or worse removed the t-stat entirely.
Brain75
984
Colorado
215/70R14
the better way to avoid the cracking issue is to find a radiator from a 4.0L explorer with AC, they are double width but still single core - swap the radiator out for better cooling ability.(it's on my own todo list as soon as the junkyard isn't a skating rink)
rumblecloud
1,416
48022
Ranger Splash
1-1/2 inch front leveling
Stock
What's the worst that could happen?
Yeah...mine has been stuck on C too --- but that's because it's
MINUS 2 F-ING DEGREES... :ROFLMAO:
rusty ol ranger
2.9 Mafia-Don
9,005
Michigan
177 CID
Yeah even my big chunk of hot iron 460 had trouble warming up yesterday. It was -3 when i fired it up (but kudos to my 10 year old interstate battery that, while not very happy about it did crank enough to fire it)
It took it about 15 minutes of driving before the temp gauge quit dancing around.
OP...
First thing id do is check the gauge, make sure its working. Pull the sender wire off, ground it out, turn the key on and see if the gauge runs all the way up to "H".
If that checks out pull the thermostat. Its likely stuck open.
I run a 185 in my 2.9 and heats never been an issue in the cab
lil_Blue_Ford
Cut & Weld
TRS 25th Anniversary
8,258
Butler, PA, USSA
5.0l
4”
Yup, you got something going on…
I’ve run a 4.0 radiator with a 180* thermostat and a good water pump for years in my Choptop and yes, I have and do run it in winter. With a good heater core and everything working as it should, it has never had a problem kicking out heat.
The sensors do fail, but at this age of vehicle, there can also be other issues.
Similar threads
Truck of The Year
Kirby N.
2024 Truck of The Year!
Vagabond Video
