coolant consumption/intake manifild? 2000 4.0L
waynetn
Hi,
I have a question for you. A few months ago, my wife's 2000 Ranger 4X4, 4.0 Vin X, began to consume coolant, and miss at startup. The problem was coolant in the LF and RR cylinders. Never overheated, never pressurized the cooling system. I assumed a leak into the intake port. Fast forward, problem is much worse, misses at idle always, runs great above 1000 RPM. Actually fouled ALL the plugs with coolant a few days ago- cool morning, no start. Cleaned them, drove it two days, basically the same. Misses, collant smell from exhaust now quite pronounced. NO oil contamination.
I pulled the lower intake. The coolant ports are SO FAR away from the intake ports that I have trouble believing that it is the source of the coolant, although the intake valves on the two cylinders it misses on are QUITE washed of carbon, and there is a nice clean swath through the carbon in the intake port. The rearmost bolt at the RR was quite loose.
I called my friend who runs a machine shop and he said the 4.0 heads are bad to crack between the valve springs (isn't that pre-1998?), and told me where to look. I see no cracks. I have read of the exact same symptoms on other forums, but no EXACT fix. I am about to seal the coolant ports with small plates, fill the intake ports with soapy water, use my regulated cooling system pressurizer to put 18 PSI or so on the cooling system, and look for bubbles in the intake ports, unless someone in the know about these rats tells me this is a common failure, and here's the fix.
Last thing- are there coolant passages sealed by the gasket between the fuel rail and the lower intake? It's dark out back, so I haven't taken that apart yet. SOMEHOW coolant is getting into the intake side of this engine, but not directly into the combustion chambers. No pressurization. Do the heads crack ABOVE the valve seats into a coolant passage?
Just for reference, I am a 30+ year veteran ASE Master, Chrysler Master, blah, blah, blah. Just never seen this before, and having trouble believing the vacuum from the port pulls the coolant over to the intake port without getting enough in the oil to show up. See what I mean?
Your response GREATLY appreciated,
Wayne Wright
homeless69
Chesapeake, VA
My truck did the same thing right after I bought it. Cracked aluminum heads, both of them, who would of thought brand new right? Well ford ended up putting cast iron heads on. Well a few years after it started again and I have just delt with it. When I start mine up it studders for a few seconds then it cleans up and runs great. You got the same smell of antifreeze from the exhaust as i do. Oil is fine. If I was going to do it myself I would take the heads off get the magnetic dye penetration inspection done which I actually have at work and then you will find the cracks or your pressure test might work too. Just because you cant see the cracks doesnt mean its not there. Funny thing for me is my compression and vacuum tests are exactly where they are supposed to be. Never took the heads off just didnt have the time. Hope you figure it out. Good luck.
Bird
5
San Antonio, Tx.
Homeless - FYI, if your talking about the 2000 Ranger you have in your sig, the 4.0 OHV never had aluminum heads.............................
Bird
homeless69
Chesapeake, VA
Guess thats what I get for listening to my service advisor haha. Thanks for the correction Bird.
