considering carpet delete
That_4.0_ranger
152
Appleton,W.A.
4.0, 2.9
stock
31x10.50-15
my new 87s carpet is so moldy and stained probably has like 10 std's but i considered ripping that out and either buying new carpet or doing a raptor liner floor what are yalls opinions
Junk Collector
Truck of Month
4,799
Rapid City SD
I had no floor covering in my '86, my F150, and my 2 door Explorer. I put vinyl in the '86 from ^ that place and I like it. F150 got junkyard carpet. The Explorer will probably not get anything.
No floor covering is OK but you get a lot of road/engine noise. Floor will get hot from the exhaust. Any wiring that's under the carpet is now exposed and susceptible to damage when you step on it. If you care about noise and temperature control, put something over the floor.
You could take your current carpet to the car wash and pressure wash it. I have done that many times with some really nasty old carpet that turned out looking pretty good. Just let it dry in the sun for about a week...halfway through flip it over so the other side drys out and hang it on something.
superj
2,577
corpus christi, texas
ranger edge
3 liters of tire smoking power
none
none
235s
Grew up in the 70s, 80s, and 90s
i would wash it, too.
but we have gotten trucks with vinyl flooring and gotten carpet remnants from the store and cut it to fit also. you get way more color options getting remnants from a home carpet place but get the short rough commercial type carpet so it withstands your boot heel digging into the same spot all the time
mikkelstuff
468
Brighton, CO
SenorNoob
567
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
I've had a couple trucks where the carpet was just 2 hallway runners overlapped under a bench seat. I didn't even notice till I started taking things apart.
