misterW
- Feb 15, 2010
- 4
- Ford
I have a 91 3.0 which has had erratic periods of no starting. Most of the time it started...except when I needed to be somewhere. I THOUGHT I had found the answer, but after looking over a trouble shooting manual, I am confused.
I had previously tested the 12v red and green power wire going to the coil and it had been fine when tested. This time, however, I tested it when the key was in the START position, instead of the RUN position, like I had done before. And this time, I didn't get any voltage. I thought this must be the answer -- how could it spark without power to the coil? I jumped a wire to the red and green power wire to see what would happen and the truck started. Seemed like the problem was solved.
But while tracing the course of that red and green wire, I looked at a trouble shooting manual for the truck and it appears to say that the red and green wire circuit is closed only in the RUN position. How does that make any sense? How can the truck start without power going to the coil? am I misreading this? I attached the chart from the trouble shooting manual below.
