Comp Cams 4504-16 Rocker Arm Stud Torque?
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
Duty, Honor, Country
Upgrading the heads and reusing the same rocker arm studs. Cannot find correct torque anywhere.
Does anyone know the correct torque for the Comp Cams 4504-16 Rocker Arm Studs?
Thanks!
Mark
franklin2
1,745
Virginia
Wouldn't the torque used for the original stock bolts work for the studs? They both are 5/16 thread into the head correct? The stock rocker bolts were 18-25 ft lbs.
Junglejoe
66
Columbia Missouri
6.0
Twisted wedge studs are 55ftlbs on rr studs
franklin2
1,745
Virginia
55 ft lbs seems like a awful lot on a 5/16 bolt or stud.
Here's a link that has a universal torque values depending on the size of the fastener.
Junglejoe
66
Columbia Missouri
6.0
Thats Trick Flows specs
markinms
17
MS
5.0L EFI
4"
31 X 10.5 X 15
Thanks for the feedback. It's been very frustrating!
I found four recommended torques from four different sources (not including the various forums I asked for help on). A user on Summit racing stated 13 ft-lbs, a user on Amazon stated 50 ft-lbs for aluminum heads and 55 ft-lbs for cast iron heads, ARP (the maker of the Comp Cam Rocker Arm Studs) recommends 24-30 ft-lbs, and finally a Tech Support Rep at Comp Cams stated, based on his experience, that a 5/16" bolt/stud should be torqued to 30-35 ft-lbs. Not one source provided the actual torque for this specific product.
Since the original stock bolts were torqued at 18-25 ft-lbs, and ARP recommended 24-30 ft-lbs, I decided to go with the Comp Cams Tech Support Rep's (and ARP) recommendation of 30 ft-lbs.
Hope this helps someone else who may be considering using these rocker arm studs.
Mark
franklin2
1,745
Virginia
Good choice. I would be very uncomfortable putting 50+ ft lbs on a 5/16 bolt, stud, or even the threads in the head.
