- Mar 20, 2019
- Reaction score
- 1,504
- Location
- Virginia
- Make / Model
- Ford Ranger XL
- Engine Type
- 2.3 (4 Cylinder)
- Automatic
- 2WD / 4WD
- 2WD
- Total Lift
- Stock
- Total Drop
- Stock
- Tire Size
- Stock 225/70/15
- My credo
- I don't count birthday's anymore...just happy to be looking down at the ground instead of looking up
Trans in your 2004 and my 2009 are different...your may have the trans temp sensor, but the 5 series dosen't..If there is one, I can't locate any info on it and they do not list a trans temp sensor replacement anywhere for a 2009.In case it's helpful, the Transmission Fluid Temperature (TFT) PID on my 2004 Ranger (V6) is Mode $22, PID $1674. Formula is "AB/8", in degF. I suspect that it may be the same on your 2009 4-cylinder Ranger's ECU.
I admire the ScanGaugeII but don't own one, so you'd need to translate that info into ScanGauge-friendly "TXD" and "RXF" (etc) commands, but their "XGauge Coding Information" manual has all the necessary info and I suspect you may have already done it for other data points (e.g. your motorhome).
