Coil Pack it in
RANGERKIM
Lakewood, CO
I have a 2004 Ford Ranger with 4.0 and Standard transmission. About a year ago now we had been having the Check Engine light come on so I replaced the coil pack. That worked for about 6 months until I drove to Denver for a job. When I reached Denver, O'Reilly's checked it out and said #4 cylinder was misfiring. I changed the plugs and that lasted about a week. I put on new wires and NO engine light. I drove to Tulsa with no engine light, picked up needs and headed back to Denver. On the way the light came on but never blinked. I drove on across Kansas. After arriving, on its own, the light went out. I had O'Reilly's check it with the light off and still #4 cylinder was misfiring. We only drive it on occasion for local errands The light stayed off until last week. O'Reilly's now says its #6 cylinder misfiring. We would like to drive back to Tulsa in spring but don't want to break down on the way or ruin the motor either.
Whats my next move?
Nearly Stranded
Dirtman
13,326
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
You never mentioned if you did wires? Also my first thing to do with a miss after a tune up is compression check. Wet/dry relative. Especially when it keeps happening on one cylinder. (Or a connecting cylinder).
RANGERKIM
Lakewood, CO
Whats my next move?
Nearly Stranded
I did on ask a mechanic when I signed up but I guess I forgot to you. Yes I did the wires as well. I will try the compression check.
Thank you.
8,296
Welcome to the forum
Did you write down the exact code or codes?
Really need those versus a parts guy telling you what they mean
Misfire means the Cam sensor detected less power when a cylinder should have added power to the engine
Nothing to do with spark specifically could be fuel injector or compression issue, as said
But could be spark so changing older spark plugs and spark plug wires is never a bad idea, new coil pack was a bit over the top
When you get codes like P0304(misfire #4) and P0306(misfire #6) it means there were multiple occasions when that specific cylinder didn't add power to the crank, so it has to happen quite a few times for CEL to come on
Flashing CEL means misfires are occurring RIGHT NOW!!!! so back off the throttle or engine damage can occur
When you have the codes read again there should also be Pending Codes and maybe History codes, get all of them and write them down
The reason is the amount of codes available for the computer to use is ALOT, list here: https://therangerstation.com/tech_library/OBD-II_codes.shtml
So exact code numbers are very.......very important, "I think it was..................." is worse than no code, lol
RANGERKIM
Lakewood, CO
I will return Friday since I am off. My wife had it checked and all they gave her was a diagram but no codes. When I went before they gave me those codes. I will be in touch as soon as I can get free again, at least by Friday.
Thanks
cbxer55
763
Midwest City, Oklahoma
I have a 07 Mustang with a 4.0. Don't know if it's the same engine. Anyhow, got a P0300 code for Random Misfire. Replaced the coils with Accel Supercoils. Wires with JBA Power Wires. New stock plugs. The cel hasn't come back on yet. But I do have a P0300pd code (pending code, won't turn on the cel), which has been there for like a month. Fuel pressure is good, so assuming the filter is good. Going to change it anyways, since I bought the car in November and assume the previous owner never changed it. Also running some fuel injection cleaner in the tank in case it's a dirty injector issue.
Kirby N.
March Truck of The Month
