- Oct 24, 2012
- 520
- Middle Tennessee
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0
- 2WD / 4WD
- 4WD
- Total Lift
- 1.5" Front + 4" Rear
- Tire Size
- 245-70-R16
I've been getting this code at first intermittently now constant (since the swap) as soon as the O2 sensor kicks in. Even when the check engine light is on I can connect a voltmeter to the O2 sensor and it reads a fairly steady 0.8. When first started it's at about 0.05 then starts climbing immediately.
My biggest question is how can there be a LEAN code when the O2 sensor is reading rich?
I did have the O2 wiring wrong (signal and ground crossed) when I first swapped the engine in. Is it likely that I managed to burn out the ECU?
And if the ECU is burned why I am I not getting a code for system at adaptive limits. Doesn't that imply that the computer can adjust and cause the O2 to start switching?
I've tried to read the plugs and can't make anything out of them.
Can't find a vacuum leak anywhere. (Cause one and the O2 reads 0.01)
Cleaned the MAF.
New Motorcraft O2 sensor.
Other useful info:
1992 Explorer ECU
1991 Explorer Harness (From automatic)
1994 Ranger Engine (And original orange injectors)
Sorry for the LONG post.
Cleaned the MAF.
Other useful info:
1992 Explorer ECU
