Clutch Safety Switch
helpme
20
Hotlanta
What year did Ford start putting a clutch safety switch on Rangers? Thanks.
RobbieD
2.9l Mafia
4,432
Georgia
I don't know for sure, but I would guess, or even bet, that this was the norm from the first ones in '83.
helpme
20
Hotlanta
Thanks. OK. Here's what happened.
Clutch master went out and I had it towed to a "profesional" tranny shop. They replaced the clutch master but when I got it back, I noticed it would start up without the clutch being depressed. Odd???
I figured they put in the wrong part from an old ranger that did not have that feature. The shop's manager said they order replacement parts by VIN.
Another problem is the pedal is very stiff. Seems to be shifting between gears OK. I tried lubricating the rod with WD40 but not much help. You don't suppose they put ATF fluid in there instead of brake fluid.
This shop was top notch say 10 years ago but they have had an ownership change and I have seen some negative reviews in recent posts.
So, how does that clutch interlock feature work? I noticed there is a module that free floats on the pedal rod. Thanks.
SenorNoob
TRS 25th Anniversary
1,356
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
IDK about the stiff pedal, but you did describe the clutch safety switch. It looks like this:
helpme
20
Hotlanta
My switch module floats freely on the rod. There is supposed to be an orientation clip on the end of the clutch master that clips into the switch that is not there. Looks like maybe it never had one. Thats why I think this clutch master is for another vehicle.
helpme
20
Hotlanta
Checking around it looks like the 95 clutch master has the orientation clip on it.
helpme
20
Hotlanta
Are the V6 clutch components different from the 4 cylinder ones? A friend has a 4 and the clutch master is different than mine.
19Walt93
4,884
Canaan,NH
351
3"
235/55R16
Clutch safety switches were first installed by Ford in about 1984. We got a load of F150's and one on the top of the car carrier wouldn't start. I had to climb up the side of the trailer, get into the truck and stand on my head to plug the switch in so the car carrier driver could get it off his trailer. I didn't realise that they can't see the ramps in front of them when they drive off those things.
Wallows in rivers
21,516
SW Iowa
That switch started in '88, earlier ones were not floating on the rod like that.
I keep the shunt from my truck's automatic days in the glovebox in case the switch acts up.
helpme
20
Hotlanta
It seems that the clutch master is from a 4 cylinder. A friend has a 94 4 cylinder and his clutch master does not have the spring clip on it. SO, the 4 cylinders are different than the 6 cylinders clutch masters. That might explain the stiff pedal also. I went back to the tranny shop and they stonewalled me. I explained that that feature is an NHTSA safety mandate and it needs to be restored.
RaceRanger97
December Truck of The Month
Vagabond Video
25th Anniversary Merch
TRS-3 Ford Ranger Sponsors
